glyn's xr4i project
Started by glyn, June 12, 2006, 23:01:09
glyn
i had that with 215/45/17 on mine, had to mod the strut to miss, remember i have 4x4 struts on cossie hub carriers tho.
could be easy sorted with thin spacers?
glyn
Quote from: maddoldbugger
glyn
mm 17 are big Ton if the tyres were a little narrower they'd miss don't like spacers but dont mind skinny ones..we'll see lrt you all know..glyn
simon
could you make a spacer from the old discs on the lath?
at least they wont move then
glyn
Quote from: simon
thats me plan SIM
glyn
Quote from: glyn
thats me plan SIM
sorted suspension problem bit of mods on the leg small spacer and 195/50/15 tyres instead of the big boots on the front,got me 2 down pipes made up,working on water hoses next,any on the market that will fit? using 4i rad and the fan in the front,done away with the viscous fan.still got plenty to do,need to make some extra thread on the rack to adjust the tracking,its toe'ing out to much,run out of thread with the grany rack and 4i ends  thats all my problems for now,see how i get on this week....it still starts ok so well pleased...regards to all   glyn
glyn
Quote from: glyn
been away a few days,but been on the car today,connecting power steering up next,starts on the key now,zorst is complete got 2 tyres to put on tomorrow and it will be back on its wheels ready for mot...not alowed to do my own its our policy...hope i aint missed much regards to all glyn
glyn
#156
trying to get some pics up here i'm having problems..glyn
simon
#157
glyn
simon
glyn
Quote from: simon
i got there :lol:
cheers,..glyn
Looking good there that man
By way 2.8 thrust bearing I take it you got one in the end, as I've found what and where you can get them from.
glyn
yea taps m8 bought 2 clutch kits in the end no problem i'll get rid of the spare bits easily ,,hope u ad a good day..glyn
Quote from: glyn
Not bad m8
For future ref if ya ever need just the bearing, Make: Premier, Part No: BRT 386
glyn
Not bad m8
got a jo left ive never done.i aint ito glass especialy rear bonded,autoglass man was suposed to do it for me on the qt but aint turned up.anyone done one? i can get some glass suckers but no sucker to help me    any tips..cheers thats alls left...glyn
glyn
Quote from: glyn
the chap turned up today yippie he done a great job charged me 30 quid well worth it,put spoiler on ,no wipers at the moment gotta check it out ...so mot shortly...  glyn
simon
great at least it aint gonna be rainng in now
glyn
Quote from: simon
sust the wipers out too,forgot the earth strap from the body to the motor on the front,nothin wrong with the back,hadnt connrcted the cables  so it looks like all systoms go now....glyn
glyn
#168
Took it for mot today it passed ,didnt do it myself i'm on sick,the warer pump is leaking bad so it'll have to come off,this wasnt new it seems to be leaking between 2 bolt holes very strange as it had a new gasket,so its back to the spanners over the weekend  hope you'r all well....glyn..ps planing my moggie 24v next,can i put it on here it'll be all ford gear?
glyn
#169
A little by the way,if you buy the bga engine gasket kit the water pump will leak as its the wrong shape the boys in the garage made me one it's now ok,also the rocker cover gaskets could do with a little bit taking off the metal insrts so that they will tighten down a bit more,had a slight leak but cured it like that...car is now on the road but i can't drive it as yet...regards glyn
Well done Glyn
Quote from: glyn
The answer is in the title m8 FORDPOWER, will the moggy be ready for Ford Fair
Quote from: glyn
if you buy the bga engine gasket kit the water pump will leak.
Perhaps you should have brought a BOA gasket set in stead of a BGA one
glyn
Well done Glyn
I REALLY SHOULD HAVE NOTICED the bottom of the gasket were the bottom hose outlet is on the pump was,nt covered by the gasket,i put hylomar all round the pump stuck the gasket on the pump and then onto the engine didnt cheeck it and there was no gasket on the old eng ony silicone type so there u go,the issue with the rocker gaskets,has anyone else had leaks with them?cured now with scimin the inserts 20 thou off   glyn
glyn
#172
Quote from: glyn
me spare engine ,trying to get a pic here
Quote from: glyn
nearly there
[attachment=1][attachment=2]
Well done mate you posted 2 pics
Told you it would look good in a photo.
Now you need to copy that lot into the forsale sections
Saw Glyn's car today.
Sounds sweet, & looks good to.
Nice clean conversion that is & a daliy driver.
glyn
Quote from: Dave
Nice clean conversion that is a daliy driver.
you got back ok m8...nice car yourself    glyn
xr4man
oh man, that engine looks soooo sexy.
