Granada Cosworth 1992
Started by dave73, June 27, 2025, 17:58:02
dave73
Quote from: Jaanus on July 20, 2025, 01:08:58 Sierra/granada/scorpio lsd units are sealed though, gear oil does not touch lsd discs
Thank you
dave73
Quote from: capri v8 driver on July 24, 2025, 09:46:35 You only need the oil.
Since you have a Viscous LSD there is no need to buy the friction modifier.
Thsnk you
dave73
How do I get the steering wheel off the Granada Cosworth.
Also the right exhaust drop down pipe off the manifold, there doesn't aeem to be any room or angle to get a socket on the two nuts from below.
How to remove the steering wheel: https://www.fordscorpio.co.uk/manual/steering/SteeringWHeel.pdf
As for the down pipe. Normally you use a socket with a flexible piece and a extension to reach the 2 nuts. Key is to get get the car high enough to get as much room underneath the car as possible to maneuver your self in a good position.
